Activity › Forums › Creative Community Conversations › This looks interesting
Posted by David Mathis on August 22, 2017 at 7:17 pmIt now looks like Final Cut Pro X is not the only NLE with a trackless timeline.
https://www.doddlenews.com/news-room/mistika-insight-a-different-kind-of-free-editing-app/
Thoughts?
Oliver Peters replied 9 years ago 3 Members · 3 Replies -
Oliver Peters
August 22, 2017 at 7:35 pm[David Mathis] “It now looks like Final Cut Pro X is not the only NLE with a trackless timeline.”
As I noted as an aside in another thread, Mistika’s UI stems from Jaleo, which was developed in the 90s. It used this open grid-style timeline without tracks – years before FCP 1.0. Although not node-based, it uses the sort of timeline window design typical of many node-based compositors. For example, you can have two versions of the same edit floating around within the same timeline window. Wherever your cursor is parked is where you see the output video.
In general, Mistika is designed as a finishing tool and not so much a start-from-scratch, creative/rough cut/”offline” editing tool.
– Oliver
Oliver Peters – oliverpeters.com
Bill Davis
August 23, 2017 at 8:23 pm[Oliver Peters] “[David Mathis] “It now looks like Final Cut Pro X is not the only NLE with a trackless timeline.””
If “tracklessness” was the driver in X it would be one thing.
But that’s just one aspect of a pretty cohesive approach to scene assembly. Magnetic timeline behaviors, vertical relationship pinning, and the default of clip creation that can accommodate audio AND video in a single cohesive unit – all work together in X to make it work as it does.
IMO It’s “tracklessness” would be a very different thing without all the other factors working in concert.
Creator of XinTwo – https://www.xintwo.com
The shortest path to FCP X mastery. -
Oliver Peters
August 23, 2017 at 8:58 pm[Bill Davis] “If “tracklessness” was the driver in X it would be one thing. “
I completely agree, which is why I said it was a non-issue in another post. However, it’s the fans who keep whining, “but it’s got tracks” every time someone posted something about another NLE.
– Oliver
