Activity Forums Apple Final Cut Pro Legacy This is probably….
  • This is probably….
    Posted by Scott Witthaus on June 2, 2005 at 11:58 am
    …a very dumb question.
    But I woke up last night thinking about it, and only have had one cup of coffee…
    A client is bringing in a projects that includes a FW drive with DV files on it. Can I just directly import those into FCP4.5 or will they need to be converted to QT’s before import? Thanks.
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    Greybox, LLC
    Richmond, VA USA
    http://www.greybox.cc
    Scott Taylor replied 21 years, 3 months ago 3 Members · 2 Replies
  • Trinity Greer
    June 2, 2005 at 2:00 pm
    No conversion necessary unless they are .dv files, then maybe the file extention may need to be renamed .mov
  • Scott Taylor
    June 2, 2005 at 10:50 pm
    If they are .dv files, then I believe that means “DV Stream” format, which is what iMovie captures. Are these files from iMovie? FCP will import these without further conversion, but the audio portion is problematic – audio will have to be rendered, every time you make the slightest change. I think you could overcome this by exporting your timeline to a QT movie then bring it back in again.
    Scott
