Activity Forums Apple Final Cut Pro Legacy This is pretty stupid but…
  • This is pretty stupid but…
    Posted by Chris Poisson on June 20, 2006 at 1:37 am
    After almost 5 years the stupid little latch on the door of my DSR-11 broke off one if it’s little nubs that serve as part of the hinge on the door. So, I now have a perfectly good DSR-11 with no door that will hang on to it.
    I did a Google search to find a new door to no avail. Seems like a perfectly stupid simple request, you’d think that Sony would have thought to make the freakin’ door at least as robust as the rest of the machine, but doesn’t seem so. Anyone know where to get a new door? (I can’t believe I’m using this forum for this, oy!)
    Have a wonderful day.
    Steven Gonzales replied 20 years, 2 months ago 10 Members · 11 Replies
  • 11 Replies
  • Jonathan Miller
    June 20, 2006 at 1:42 am
    Man, I feel your pain.
    Mine broke off, too.
    I repaired it using a toothpick!
    I just cut the very tip of the toothpick off, and superglued it to the door. Then, you insert the toothpick end to the DSR-11 first, and then the end that is still intact second. Click!
    The wood of the toothpick can “squish” a little so it doesn’t have to be a perfect fit!
    Well, at least it worked for me…
    Good luck!
    Jon
    TreeLine Productions
    Fort Collins, CO USA
    Currently producing these popular podcasts:
  • Captain Mench
    June 20, 2006 at 3:26 am
    I think if you take a poll… 75% of the owners of this fine box will tell you their doors are broken…. Mine? Well — sorry – it’s still there… as of today.
    CaptM
  • Steven Gonzales
    June 20, 2006 at 3:27 am
    It doesn’t seem that Sony sells the door only. You would have to buy the complete “DOOR ASSY, FRONT” for $57.72. The part number is X39512842 at https://servicesplus.us.sony.biz/sony-parts.aspx
    However, repairing would seem cheaper.
  • Mark Raudonis
    June 20, 2006 at 3:30 am
    Chris,
    We’ve got six of them in the building…. all six have lost their doors!
    Consider the “doorless” version like a convertible with it’s top down… much easier to get in and out of!
    mark
  • Bouncing Account needs new email address
    June 20, 2006 at 3:56 am
    Toothpick is OK, but I prefer a bit more substance.
    Straighten out a heavy paper clip (not the little ones… use one of the 2-inchers).
    Cut its end on an angle with wire cutters so you have a sharp point.
    Hold the clip with pliers and heat up its point with a lighter flame.
    Then quickly “stab” the sharp end into the edge of the door where the “nib” WAS (not too far).
    Let it cool and become “stuck” in the plastic of the door.
    Cut off excess clip, leaving just enough to become a “new” metal “nib”.
    Remount the door.
  • Michael Horton
    June 20, 2006 at 4:57 am
    We use one for lafcpug meetings and have for about 5 yeras. Door broke off after 6 months. We left it off. I think a DSR-11 with the door on it is a collectors item
    Michael Horton
    lafcpug
    https://www.lafcpug.org
  • David Roth weiss
    June 20, 2006 at 8:01 am
    Mine is broken too.
  • Walter Biscardi
    June 20, 2006 at 11:51 am
    [Michael Horton] “. I think a DSR-11 with the door on it is a collectors item”
    Hmmmm, wonder how much mine is worth. 3 years and still has the door……
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Tony
    June 20, 2006 at 3:23 pm
    Sending the unit would most likely be much more expensive.
    Last I checked Sony Depot repair rates were $120-130/hr (usually four hr minimum billing) plus it takes forever (over two months) for gear to be repaired.
    Tony Salgado
  • Chris Poisson
    June 20, 2006 at 5:40 pm
    Geezus, it shouldn’t be “Matte,” it should be “MacGyver.” Fixing a DSR-11 with a paper clip and a lighter, just too brilliant. Worked like a charm on my end too. Wow.
