Activity Forums Adobe Encore DVD This is Driving me Crazy!
  • This is Driving me Crazy!
    Posted by Justin Jones on December 22, 2007 at 6:57 am
    Okay guys, I am going nuts here!
    I am in the process of cutting a dvd of my demo in encore cs3 and cant get it to even consider loading or transcoding .m2v’s… I have imported avi’s just fine but it locks up when it comes to transcoding the video. It seems like a problem with the codec but since it works fine encoding m2v’s in premiere I dont really know. When I try to import the .m2v’s from premiere I get nothing. Encore just sits at importing window and it never progresses. I tried the process I saw in another post for fixing a load loop which I don’t think this is, since it didn’t work. Any of you masters out there have a different solution? thanks guys.
    Justin
    Belinda Edwards replied 18 years, 9 months ago 2 Members · 2 Replies
  • Justin Jones
    December 23, 2007 at 2:07 am
    Fixed the problem… Looks like a conflict with either dual displays or my driver build version since updating the video driver seemed to fix the problem. If anyone else has a 8800 GTS with the same issue then you know the solution
  • Belinda Edwards
    December 23, 2007 at 10:24 pm
    Can you use a program to convert your m2p files to mpeg and try that? Just a thought. I am working on a wedding video, and am using m2p file in the menu, and they seem to be working okay. I’m not a master at this, but maybe you could convert your files to mpeg2 and try that.
    Good luck, God Bless & Merry Christmas
