Activity › Forums › DaVinci Resolve › This is basic. Send 23.98 sequence from Fcpxml, Resolve sends 24.0 XML to fcp7.
  • Joseph Owens
    March 1, 2013 at 10:57 pm
    I’m getting 29.97 projects back as 30 fps, and the cut-n-paste workaround is not my idea of a bug fix.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Jeremy Garchow
    March 1, 2013 at 10:58 pm
    [Joseph Owens] “I’m getting 29.97 projects back as 30 fps, and the cut-n-paste workaround is not my idea of a bug fix.”
    If you change the NTSC flag in your XML from false to true, does it work for you?
  • Joseph Owens
    March 3, 2013 at 7:02 pm
    In the (Resolve) generated XML for the return trip, do you mean?
    jPo
  • Joseph Owens
    March 3, 2013 at 7:10 pm
    The answer is yes, changing the flag to “true” does yield a 29.97 returned sequence, even though a couple of lines up from there the frame rate is 30.
    jPo
  • Jeremy Garchow
    March 3, 2013 at 7:23 pm
    The frame rate is always a base 24, 30, 60.
    The NTSC flag signifies 23.976, 29.97, 59.94, etc.
    If this is the only flag being misrepresented, it may be the bug. I had a chance to test it all the way through, though.
    At any rate, it should be fixed by blackmagic.
  • Paul Provost
    March 3, 2013 at 7:41 pm
    Ok so Resolve is changing the xml ntsc/true flag to false on import into resolve then.
    http://www.4Kfinish.com | owner-colorist | Hollywood, CA
    http://www.facebook.com/4kFinish
  • Jeremy Garchow
    March 3, 2013 at 8:27 pm
    *edit
    That’s what I’m seeing.
    I think that’s what jpo is seeing.
    But I haven’t followed all the flags all the way through to see if it makes a difference, because if that one is wrong, are the rest of them wrong? Does it make a difference in playback?
    Not enough hours in the day…
    *I can’t type
  • Jeremy Garchow
    March 11, 2013 at 4:42 pm
    This is pretty messed up.
    Other clips getting flagged as 24.0 as well.
    I have to check all NTSC flags.
    Jeremy
  • Robert Due
    March 11, 2013 at 4:51 pm
    I do agree that it is a bug that should be fixed by BMD. I also check my cut and paste method and it worked for me. (Mileage may vary)
    I was dealing with one type of ftg. (RED) Perhaps mixed media results in frame rate issues. I have had footage from an Avid project that was 23.976 originally get rendered by Resolve as 24 fps on the roundtrip.
    I know the cut and paste method isn’t a good fix, but it seems to work for me – until the bug gets fixed, that is.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
    DaVinci 9.1.1
    OSX 10.7.5
    MacPro 8-core 4,1 2.93 Ghz
    8GB RAM
    Nvidia GT120/GTX570 (CUDA 5.0.36)
    Decklink Extreme3D+
    Panny BT-LH1710P/ Panny BT-LH2600W
    Tangent Wave
  • Andrew Smith
    March 25, 2013 at 3:06 am
    This bug is a HUGE problem! Maybe BMD doesn’t respond hear anymore? Also seeing this issue in 29.97 vs 30 from fcp7 xml – how can this be allowed to be released with such huge glaring bugs? Even worse not tell users about bugs you aware of so we can avoid client disasters.
    I just don’t get it. I have seen some big resolve 9 bugs in many versions – 9.0.4 got rid of a big one which had XML from fcp7 r3d jobs multiple frames off but now mixed frame rates in 9.1.1 is a huge pain…I want know how such a huge bug can be allowed?? BMD I know you are aware of the bugs so can you please respond to dongle owning professionals?
Page 2 of 3
