Activity › Forums › Apple Final Cut Pro Legacy › This is a stretch
Bret Williams
November 2, 2011 at 5:04 pmTry it with your RT to medium. No buzzing. Especially if you’re working in Progressive.
Bret Williams
November 2, 2011 at 5:08 pmOne other method. Nest your HD edit in a NTSC DV sequence. If the HD edit is rendered, it should play back in RT in the DV sequence, which you can also monitor via FireWire to your deck. Might even have better results than my other method.
Neal Klaeser
November 2, 2011 at 5:27 pmMy initial reason for going through all this was to monitor on a HDTV as a larger image instead of watching the video in a 5″ canvas window. I wasn’t even that concerned whether it was being viewed on a professional HD monitor a consumer monitor would of just been fine to me. With this client, I shot green screen and wanted to view it larger to catch errors in the key. But, it seems it’s a little more complicated than first thought.
Neal Klaeser
Real to Reel Productions
http://www.realvideopro.com -
Rafael Amador
November 2, 2011 at 5:28 pm -
Shane Ross
November 2, 2011 at 5:34 pm[Rafael Amador] “You get 10b out monitoring with ioHD through the FW800 of the iMac.”
But it takes over the Firewire bus so you cannot have a firewire drive attached to the iMac as well…meaning the drive containing your media.
That and it costs $3400…
Shane
Read my blog, Little Frog in High Def -
Bret Williams
November 2, 2011 at 6:45 pmI’m confused. You specifically asked for a method to monitor your HD footage on a professional SD monitor. You didn’t mention wanting to monitor on an HD monitor.
Bret Williams
November 2, 2011 at 6:50 pmIf you have a second cinema display connected, just go to VIEW- Video Playback – Digital Cinema Desktop Preview
The second monitor is now a video monitor basically.
Rafael Amador
November 3, 2011 at 4:37 am[Shane Ross] “But it takes over the Firewire bus so you cannot have a firewire drive attached to the iMac as well…meaning the drive containing your media. “
Your right Shane.
i was thinking on the new iMacs with Thunderbolt: The Thunderbolts for media and the FW800 for the card (that’s what I expect to do to keep running my eSAT drives and my ioHD).[Shane Ross] “That and it costs $3400…”
This I was thinking on second hands. I thought would be a bunch in eBay 🙂
rafael -
Neal Klaeser
November 3, 2011 at 6:43 pmI tried outputting through the mini- display port to a DVI connector going to a HDTV monitor but was unsuccessful because of some unknown reason. So, I accepted the fact that I wasn’t going to be able to accomplish this so I thought the next best thing would be to monitor the HD signal through an SD monitor.
Neal Klaeser
