Activity Forums Adobe After Effects This GIF effect ?
  • This GIF effect ?
    Posted by Arun Prasad on February 12, 2016 at 5:35 am
    Hey Guys,
    It feels great to be in here and this is first time am making a post…
    The reference link:
    https://dribbble.com/shots/2520799-The-Edit
    I’ve came through this animation while i was dribbling. I am wondering how he would have got this effect… I’m having some ideas popping up but couldn’t render the final output perfectly.
    1. Particle system
    2. Null Object
    3. May be Write on
    4. Parenting the Particle system position to null object position
    But how he would got this delayed line effect ? Enlighten me if possible.
    Dan Fassnacht replied 10 years, 6 months ago 4 Members · 4 Replies
  • Kalleheikki Kannisto
    February 12, 2016 at 11:29 am
    I’d assume the particle trails were done in Particular.
  • Chris Evans
    February 12, 2016 at 4:32 pm
    He says this on that same page.
    [Arun Prasad] “The first part uses the hair render in C4D with transparency for the fall off.
    For the second part I would just duplicate the path, and use a gradient stroke as a luma matte for the falloff.
    I have no idea how to do either of those things. C4D I’m sure would just take some learning, but as far as I know, there is no such thing as a gradient stroke in After Effects. You could use the echo effect.
  • Arun Prasad
    February 13, 2016 at 5:10 am
    Hey Guys ! Thanks… I think i’ve nailed the effect in both After effects and in C4d !
    Its C4d !
    And here’s AE
    Thanks for the help guys.
  • Dan Fassnacht
    February 17, 2016 at 11:20 pm
    Can you share your C4D technique?
