Activity Forums Adobe After Effects This FX…how?
  • This FX…how?
    Posted by Lorenzo Di rienzo on November 8, 2007 at 10:10 am
    Hey you all, i was trying to understand and then emulate an effect i saw on a music videoclip.
    You can see this clip at the following url: https://it.youtube.com/watch?v=p2lhiesbSo4
    Obviusly the fx i’m trying to reach is the “timewarp stretch fx” on the body of the singer.
    I tried several times with “Echo” Fx but the result i got is different because of the way Echo works. So i’d like to not have previous frames to repeat in time but to stretch the actual frame.
    Does anyone know how to do this?
    Thx a lot and sorry for my bad english.
    Cya!
    3fingers
    Lorenzo Di rienzo replied 18 years, 10 months ago 7 Members · 9 Replies
  • 9 Replies
  • Amit Zinman
    November 8, 2007 at 11:23 am
    Why not just do it with a mirror? Seems less messy.
  • Lorenzo Di rienzo
    November 8, 2007 at 11:33 am
    Thx Amit but i don’t think i could archieve that FX just using a mirror Fx….seems to be more complex and accurate…
  • Lorenzo Di rienzo
    November 8, 2007 at 1:35 pm
    Nobody helps? Please point me where i can experiment on this…
  • Matthew Mccarter (macattack)
    November 8, 2007 at 2:47 pm
    I truly have no idea. But maybe you could use vector paint to roto the subject (or green screen) and then use bezier warp?
    I’m totally baffled, but I hope that at least helps get something started.
  • Sam Moulton
    November 8, 2007 at 4:48 pm
    you’re going to need to separate the subject from the background then apply echo, pre-compose that and apply time remapping.
  • Daryl Booth
    November 8, 2007 at 5:25 pm
    Why not use Andrew Kramers Morph demon face tracking technique, then just blur the face to get the effect?
  • David Del
    November 8, 2007 at 9:21 pm
    I don’t think you need to remove the background from the footage because the camera is locked off and the other thing that moves is the singer – therefore, when it trails, the only thing moving is the singer and his echo.
  • Ns-5 Sonny
    November 9, 2007 at 11:52 am
    I think Mesh Warp was the effect used. I’ll try it later.
  • Lorenzo Di rienzo
    November 11, 2007 at 6:40 pm
    Thx to you all guys, i’ll try your suggestion, i’m sure i’ll archieve that!
    Cya!
