Activity › Forums › Adobe Illustrator › This Forum is Weak
This Forum is Weak
Posted by Charley on May 10, 2005 at 5:55 pmThis is the worst place for PS info.
Andrew J. bricker replied 21 years, 4 months ago 5 Members · 4 Replies -
Kelly Johnson
May 11, 2005 at 2:20 amI’m assuming you either:
1- got razzed for asking something that may have been considered too ‘beginner’ by some.
2- didn’t use proper grammar and resorted to silly abbreviations which meant nothing to anyone.
3- didn’t clearly phrase your question and so therefore, didn’t get a response.
4- got upset because someone wouldn’t actually ‘do’ something for you.
5- some other reason? (fill in the blank)My perception of this forum is that it is part of something bigger. It’s an educational repository of both real world and weekend rubber-stampers who share and ask regardless to which category they may fall under. Which is awesome.
Yes, this particular forum says Photoshop/Illustrator, but the Cow is the big picture.
Look in other forums, cross-search your questions here at the Cow.
Otherwise, if all you want is a Photoshop forum, may I suggest Google with “Photoshop” “tight” and “sic” as the parameters.
Mathdreamer
May 11, 2005 at 5:18 amI personally find it very valuable. The people are polite and helpful. I feel that you making a blanket statement without any reasons shows that you are right that this place is not for you.
-Rob
Steven J. gilbert
May 12, 2005 at 4:10 pmIf you can find a nugget here and a tip there, then this forum is valuable. Otherwise, join NAPP and try somewhere else.
