Activity Forums Adobe After Effects this effect
  • Ben G unguren
    September 26, 2011 at 3:53 pm
    Do some searching for “chromatic aberration.” Here’s a recent thread about it in the photoshop forum. But you’ll find lots of talk about this sort of effect all over the place; it’s been very popular over the past couple years.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Richard Harrington
    September 26, 2011 at 4:00 pm
    Actually chromatic aberration is more of a fringe at the edges due to high contrast.
    That looks more like a channel blur with some keyframes applied
    Richard M. Harrington, PMP
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
  • Sean Mullen
    September 26, 2011 at 7:33 pm
    Vlad,
    To do this effect manually, you need to mix channel separation and frame shaking.
    Channel Separation –
    Apply the Set Channels Effect to your footage (Effect > Channel > Set Channels)
    Duplicate your layer three times
    Set your shift channels to only one color per layer, turn the rest off.
    For example, layer 1 take red from red, layer 2 take green from green, layer 3 take blue from blue.
    Set all layers to Add transfer mode.
    Frame shaking –
    Apply this to effect to each layer. Set two position keyframes, highlight the keyframes and use the wiggler. In the wiggler, set (apply to) to spatial path and (noise type) to jagged. Adjust your frequency and magnitude to your liking. Hit apply. Use the Motion Tile effect with the mirror edges option checked. Play with the output width and output height to cover any space that appears around your frame. Make sure to turn on motion blur in your comp.
    Additionally you can use the wiggle expression to achieve this effect.
    There are also many After Effects distortion tools on the market that can give you this look, here’s a few that I recommend:
    Separate RGB from AEScripts
    Data Glitch from AEScripts
    Damage from DigiEffects
    Twitch from Video CoPilot
    I hope this helps!
    Sean Mullen
    Rampant Design Tools
