Activity Forums Maxon Cinema 4D This did my head in – HELP!!!
  • This did my head in – HELP!!!
    Posted by Greg Serafin on June 11, 2007 at 5:23 am
    Hi All,
    Having a major problem with what seems a simple thing: Sweep a rectangle along a linear path to create a frame – legs for an arm chair.
    Sounds like it is so simple, I could ask my cat to do it, while I watch the TV – well, it is not (at least for my cat, or me for that matter).
    Here’s the link to the explanation, screen shots and a bonus link to the c4d file.
    https://web.mac.com/i.3d/iWeb/c4d/SweepProb.html
    hope you can help.
    TIA
    IQ truly 0
    Greg Serafin replied 19 years, 3 months ago 3 Members · 4 Replies
  • Joe Bird
    June 11, 2007 at 3:03 pm
    I opened up your file and noticed that the orientation of the path spline was not +Z. This may be the problem, as the rectangle flips on the wrong axis as it negotiates the corner. See the fix .c4d file at http://www.birdhausdesign.com/public/
  • James Leaburn
    June 11, 2007 at 9:10 pm
    If you raise the maximum length setting of the spline that you are sweeping along. This may help.
  • Greg Serafin
    June 11, 2007 at 11:57 pm
    Thank you good people!
    Bear – looks like there are several overlapping polys in the corners in your file. The shape is fine – thanks, but the geometry is “un-clean”.
    jimzepellin – I must say I am not aware of the setting you mentioned.
    However I found a strange solution, I don’t understand it, but hey, after all I don’t have to, do I?
    “Round” the path with more than 6 (original) points seems to work when the path is rounded with 11 or 16 points – strange indeed.
    I must say that after 6 years of using c4d, this one really stumps me. I see no logic in the behaviour, and from where I seat, I’d be tempted to use the word bug. At the end of a day, what could be easier than sweeping a rectangle along a path?
    Thanks again, more words of wisdom are welcome.
    IQ=0
  • Greg Serafin
    June 12, 2007 at 2:44 am
    OK, it’s official, reading help helps.
    “A common mistake when using rail splines is to use a path spline with adaptive interpolation. This can generate insufficient subdivision for the rail to work properly
