Activity › Forums › Adobe After Effects › Third Party Plugin display issue
Benjamin Parker replied 10 years, 10 months ago 2 Members · 12 Replies
Walter Soyka
November 20, 2015 at 10:59 am[Benjamin Parker] “the base install of 2014 worked perfectly, unfortunately when I updated it to the latest version (13.2.0.49) the issue occurred.”
High DPI support was added in 13.1, so if that’s in fact the problem, this makes sense.
You are running Windows, right? Have you changed your text size to something other than 100% on the system? Tap the Windows key and type “make text and other items larger or smaller” — then open the control panel that comes up in the search results to check.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Benjamin Parker
November 20, 2015 at 11:44 amWalter you are a legend! after all that it was as simple as a click of a button and a restart. Thank you
“I believe our adventure through time has taken a most serious turn.”
