Activity Forums Adobe Premiere Pro Third party Mac software for timelapse movie creation from still image sequence?
  • Third party Mac software for timelapse movie creation from still image sequence?
    Posted by Don Hertz on June 17, 2017 at 4:37 pm
    I have dozens of time lapses to convert to movies in Premiere. They were all shot as still image sequences in the CR2 format – which Premiere cannot import. So I set up a batch in Photoshop to convert all the CR2’s to JPGs so I could then import them into Premiere. It’s a pretty slow process, as it can take Photoshop a long time to convert that many still images.
    Can anyone suggest a different software package that would just open the CR2 files and create a movie, which I could then export and load into Premiere? I have FCP X and Media Composer – but can’t find an easier way with either of those to do it. I miss the days of Quicktime 7 when I could just open an image sequence and export a movie in two steps!
    Thanks.
    Don
    Daniel Waldron replied 9 years, 2 months ago 5 Members · 5 Replies
  • Brent Marginet
    June 17, 2017 at 6:35 pm
    You can still install Quicktime 7 on your Mac.
    I’ve installed it on Yosemite, EL Capitan and Sierra and use it on an almost daily basis.
    Apple really did us all a disservice when then stopped developing QT on Mac.
    It is an absolute must have tool as far as I’m concerned.
    I don’t think it will open CR2 files but I just wanted you to know that it will still work on the newer OS’s
    Here’s the link for the installer.
    Just one note: It gets installed in the Utilities Folder instead of the Applications folders like it used to.
    You should also be able to find a Pro Serial Number by searching the net.
    https://support.apple.com/kb/dl923?locale=en_US
  • Andy George
    June 18, 2017 at 4:08 am
    I use after effects to render my time-lapses, it will recognize the CR2 files.
    You can set up several timelines and then render them as a batch.
    As a plus, you get the opportunity to do any edits in the camera raw dialogue upon opening the image sequence.
    Here’s a tutorial that walks through the process https://www.youtube.com/watch?v=XNuzIfXjTUI
  • Greg Janza
    June 18, 2017 at 5:41 am
    https://vimeo.com/135850608
    Adobe Premiere 2017.1.1
    Windows 10 Pro
    Samsung SSD 850 EVO system
    Samsung SSD 850 EVO Adobe cache
    NVIDIA GeForce GTX 970
    OWC Thunderbay 12t x 2 in Raid10 configuration (thru Storage Spaces and Disk Management)
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Don Hertz
    June 18, 2017 at 2:11 pm
    That was exactly what I needed! Never thought to try After Effects. The fact that I can keep queuing them over to Media Encoder and setting up the next one without tying up AE is great too. I already have over a dozen in the que and processing!
    Thanks Andy.
    Don
  • Daniel Waldron
    June 19, 2017 at 2:30 pm
    Some good suggestions already. I believe Lightroom can also export timelapses…
