Activity › Forums › Avid Media Composer › Third Monitor iMac Avid
Posted by Guy Crossman on October 28, 2021 at 3:21 pmEditing from home these days and would like to add a third monitor for full screen playback on my Avid. I’ve got an iMac (Retina 5K, 27-inch, 2017) with a 3.8 GHz Quad-Core Intel Core i5 and Radeon Pro 580 8 GB, running Catlina 10.15.7. No break out box and Monitor 2 in one of the Thunderbolt 3 ports. Can I do it? Thanks Guy
Guy Crossman replied 4 years, 10 months ago 4 Members · 7 Replies -
Pat Horridge
October 28, 2021 at 3:24 pmIf you want the 3rd screen to show full screen playback you need an output box.
Black magic AJA or similar.
Chris Bové
October 28, 2021 at 3:49 pmHello! Yes the three-display config is wonderful for Media Composer editing, and growing fast in popularity. Left display is bins and project stuff. Right display is timeline only. A third display is mounted above the right display and shows Composer window, color tools, etc. Very cool.
I have seen this done in the way you described. The only major issue you might run into is an Apple issue, not an Avid one. In Catalina… I think 10.15.6 if I remember correctly… Apple users in all industries not just media saw 2nd-display and 3rd-display issues introduced. (Some Apple users said it was only seen in a specific couple of video card configs, but I never saw that mentioned publicly.) It was still there in early BigSur versions too, much to everyone’s dismay. it affected iMacs, it affected older iMacs being used in Target Display Mode, as well as laptops.
As of BigSur 11.5.x series, I no longer hear anyone complaining about it so it must’ve been fixed or at least patched by Apple. Unsure. So if you get the gear, plug it all in, and discover something is not working, you might want to consider updating your OS. Just a heads-up.
Chris Bové
October 28, 2021 at 3:51 pmSide note – I’ve also seen this three display setup where the left display showing bins etc is mounted vertically. More for scripted and documentary users with ScriptSync and such.
Guy Crossman
October 28, 2021 at 3:54 pmThanks Chris I’ll give it a go. Right in the middle of something so don’t want to upgrade OS just yet, learnt my lesson the hard way doing that!, but will do it at the end. Thanks again Guy
Tristan Summers
October 29, 2021 at 12:58 pmWith a breakout box you can actually calibrate it properly. With a black magic one you can even use resolve.
Running three displays probably uses more pcie lanes than the processor has and you need them for any other thunderbolt devices. You could check if Apple bothered to tell you more details about their processors
People do it a lot and it seems to work for them. Been in loads of studios with 2 EXTRA UHD monitors on an iMac and hundreds of thunderbolt drives and converters. But that is really really asking for trouble.
Guy Crossman
October 29, 2021 at 1:04 pmThanks Tristan, and did they use a Black Magic box to run those extra monitors? Cheers
