Activity Forums Apple Motion Thinner outlines for shapes?
  • Thinner outlines for shapes?
    Posted by Andreas Zeitler on January 2, 2013 at 9:43 am
    Hello CreativeCow,
    I need to make rounded rectangle with a gradient fill in Motion. So far so good.
    The problem is that the rectangle needs to have a very thin outline, but Motion doesn’t let me set an outline width smaller than 1. I could set to “do not scale” and then do some scaling down, which I tried, but to get to the size I actually need, I would have to do a lot of scaling.
    I worked around the problem by importing a graphic containing the rectangle in the right size for now. I’m wondering, if it is possible to set smaller outline sizes though?
    Thanks.
    Andreas Zeitler replied 13 years, 8 months ago 4 Members · 5 Replies
  • David Eaks
    January 2, 2013 at 11:29 am
    Can you type in a smaller number like 0.25 instead of using the slider?
  • Andreas Zeitler
    January 2, 2013 at 12:25 pm
    No you can’t.
  • Aj Robinson
    January 2, 2013 at 2:34 pm
    Hey, I came up with a good solution. Make your rectangle. Well call this (1) Set the falloff to 1000 (you’ll have to type this in). Then, duplicate the layer (2) and place it under your original rectangle (1). This will be your outline. Set this rectangle (2) to the color you want to be your outline. Then, you will have to increase the X and Y scale parameters of (2) by yourself. Open up the scale drop down arrow, and scale the X to say 101. Then, scale the Y up to about 103 to even it out.
    Any Questions?
    ~AJ
  • Simon Ubsdell
    January 2, 2013 at 2:50 pm
    Try selecting Under Fill for the Outline Order (as opposed to Over Fill – the default) and turn on Preserve Width and you have full control over the width.
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Andreas Zeitler
    January 2, 2013 at 3:18 pm
    Thanks, Under Fill works.
