Activity › Forums › Maxon Cinema 4D › Thinking Particles – Particle Orientation
  • Thinking Particles – Particle Orientation
    Posted by Mathew Power on September 23, 2008 at 8:09 am
    Hi everyone. How do I set the orientation of the particles from an emitter with thinking particles. I am using a cuboid as the particle and I want to orientate it so it is pointing in the direction of travel. How can I do this?
    Adam Trachtenberg replied 18 years ago 3 Members · 4 Replies
  • Randy Johnson
    September 23, 2008 at 8:29 am
    I post an extremely simple example here:
    https://www.randyarchy.com/TP.c4d.zip
    Rotate the Pyramid primitive and press play.
    /randy
  • Mathew Power
    September 23, 2008 at 8:36 am
    Hi Randy, thanks for your help. What I forgot to say was that the particles are emitting out from a centre point so each particles needs to be orientated differently depending on where it fires from.
  • Randy Johnson
    September 23, 2008 at 8:51 am
    ha ha yea that changes it.
    I am not sure how you would do that “properly” Hopefully Brian or Adam can help you.
    With that said, i would make different particle groups that go in the different directions. I would also use an invisible polygon rather than a centre point to control the direction.
    /randy
  • Adam Trachtenberg
    September 23, 2008 at 5:12 pm
    Pretty easy, fortunately. Just check the “tangential” box in the emitter’s properties. 🙂
