Activity Forums Maxon Cinema 4D thinking particles-multi shape emitter
  • thinking particles-multi shape emitter
    Posted by Richard Quinn on May 2, 2009 at 4:09 pm
    I wanted to make a bunch of musical notes fly out of a speaker in a random way.
    I thought that the “Thinking Particles – Mulitishape emitter” in the content browser would work.
    There are 4 default shapes – cylinder, cube, cone & sphere. I thought I could swap these out with musical notes.
    I cannot see any shapes when I render, not even the original ones?
    I am a real novice when it comes to particle work. Is there something obvious I am doing wrong? Do I need to change anything in the attributes window or xpresso in order for it to render???
    Cheers,
    Rich
    Brian Jones replied 17 years, 4 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    May 2, 2009 at 11:01 pm
    You have to add a “Particle Geometry” object to your scene (Objects>Thinking Particles>Particle Geometry).
  • Richard Quinn
    May 2, 2009 at 11:52 pm
    Thanks Adam!!!
  • Richard Quinn
    May 3, 2009 at 8:31 pm
    Hi again,
    I got the multi shape to emit musical notes thanks to Adam.
    I have now added a plane object to my scene to act as a deflector for the particles. The musical notes are flying around a room so I would like them to deflect off the walls rather than go through the walls.
    I added a pdeflector node in the xpresso window and assigned my plane to it in the attributes window.
    I have no idea what to connect the pdeflector node to in the xpresso window though?????
    Any help would be great.
    Cheers,
    Rich
  • Brian Jones
    May 3, 2009 at 11:30 pm
    Use a P Pass node to pass the generated particles to the PDeflector node
