Activity Forums Maxon Cinema 4D Thinking particles going through models…
  • Thinking particles going through models…
    Posted by Justin Rank on January 4, 2007 at 1:44 am
    I have a starship model that I’ve worked up some damage on. I stuck a particle emiter inside the hole in the ship and used a fan to get the particles headed in the right direction, but the particles tend to fly right through the model in places I don’t want them to go. Is there a way to keep the particles from going through the model? I’ve tried using a deflector, but that didn’t give me the results I was looking for.
    Thanks in advance…
    Joe Bird replied 19 years, 8 months ago 3 Members · 2 Replies
  • Mylenium
    January 4, 2007 at 9:52 am
    Check the presets that come with TP. there are several that use external geometry to create tubes/ funnels to direct your particles. Other than that you need to direct your particles using some of the various force fields which is a common thing to all particle systems.
    Mylenium
    [Pour Myl
  • Joe Bird
    January 4, 2007 at 11:35 pm
    you might try regular particles and the free plug-in, Fizz.
