Activity › Forums › Maxon Cinema 4D › Thinking Particles Calculations
  • Thinking Particles Calculations
    Posted by Jan-oliver Haas on November 24, 2008 at 12:40 pm
    Hi there!
    I built a Thinking Particles Xpresso Circuit, which works well, when Rendering the Animation from the first Frame on.
    But if I want to start render some frames in between, lets say starting from Frame 200, any Properties of current Particles are lost. Only Particles which are generated after frame 200 contain the properties again.
    With Properties I mean for example Group Changes.
    Do I really have to render everything from first Frame on, if I only would need Frame 200 to 250? Or ist there an inactive button which prevents the Particles from getting Calculations from previous Frames?
    Thanks for your solutions.
    Adam Trachtenberg replied 17 years, 10 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    November 25, 2008 at 4:49 pm
    Hard to say what the problem is without seeing your setup.
