Activity › Forums › Apple Final Cut Pro Legacy › Thinking of switching from FCP 7 to Avid or Premiere
  • Thinking of switching from FCP 7 to Avid or Premiere
    Posted by David Wharton on January 11, 2012 at 4:58 pm
    Thinking of switching our edit systems from Final Cut Pro 7 to Avid or Premiere. I know this is a rather broad question, but what are folks thoughts on this? I’ve messed around with FCPX and it just seems like a mess. But the expense of switching and training staff for a new system are rather prohibitive. What are other folks doing?
    Herb Sevush replied 14 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Roli Rivelino
    January 11, 2012 at 5:23 pm
    Walt Biscardi a senior member on this forum and one of my heroes is switching all of his studios to Premiere; if it’s good enough for Walt it’s good enough for all of us.
    Premiere “acts” more like FCP so not such a steep learning curve as with AVID.
    FCP X sucks balls
    https://www.rolirivelino.com/
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
  • Shane Ross
    January 11, 2012 at 6:15 pm
    The current version of Premiere Pro CS 5.5 is lacking in many many ways. Targetting tracks takes 2-3 more steps than it should (and than it does in FCP or Avid)…it gives a bad name to TRACK BASED EDITING. Audio mixing/manipulation on the timeline is VERY time consuming (and the audio mixer effects the entire track, not individual tracks like the mixers in FCP and Avid do). Media Management is OK, but not quite up to FCPs ability, and FCP’s is weak as it is.
    PPRo is great for working natively, and allowing you to go back and forth from AE…but for broadcast work, and quicker audio mixing…Avid is the way to go. Bette trim tools, more stability. Although you still need to transcode to Avid media. AMA allows for you to ACCESS many media types natively, but native editing isn’t as smooth as it could be. Although with RED, it’s not bad. And if you work in 3D, Avid pretty much is your go-to app for that.
    But…it still has limitations that cause me to pause. 16 tracks of realtime audio playback only. Add a 17th track, and it is dark…you can’t hear it until you turn off another track. Which makes adding tracks above 16 pointless. Why they have this limitation when they aren’t limited to hardware anymore is puzzling to me.
    Both will work on your current mac and with any of your current third party capture card (with a few exceptions). Just depends of if you want to be able to edit natively, or if you need to have multiple editors on shows..and where your final product is destined to be viewed.
    Shane
    Little Frog Post
  • Roli Rivelino
    January 11, 2012 at 7:08 pm
    Mmm good points Shane, though I’m surprised you differ from Walt on what’s best for broadcast.
    Also you forgot to mention if cost is a factor then Premiere beats Avid by quite some way.
    I reckon with the fall of FCP 7 Adobe are going to step up they’re game in the next couple of years or so and really iron out some of those problems that Shane mentions. After all wasn’t it FCP that copied the Premiere platform in the first place?
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Shane Ross
    January 11, 2012 at 7:30 pm
    [Roli Rivelino] “Also you forgot to mention if cost is a factor then Premiere beats Avid by quite some way.”
    Adobe CS 5.5 production bundle is $1600-$1700, includes PPro, After Effects, Photoshop, Illustrator, Encoder, Soundbooth, On Location, Flash.
    Avid MC 6 is $2500 ($1500 if you have FCP)…and includes Avid, Sorenson Squeeze and a couple smaller things. Not a full package like Adobe.
    Shane
    Little Frog Post
  • Bret Williams
    January 11, 2012 at 9:16 pm
    [Roli Rivelino] “After all wasn’t it FCP that copied the Premiere platform in the first place?”
    Nope. Premiere was originally a one window viewer sort of thing, with lots of palettes all over as Adobe loves to do. Other NLEs of the time were all sorta different. The video cube had no window because it was always out to a dedicated monitor. Avid was the first to make the source / record analog metaphor a standard. Media 100 had it’s own one window thing. I remember EditDV copying the metaphor, and then FCP. FCP mimicked what was the standard in Avid. And I guess Premiere fell in line and copied them both.
  • Roli Rivelino
    January 11, 2012 at 11:45 pm
    [Bret Williams] “FCP mimicked what was the standard in Avid. And I guess Premiere fell in line and copied them both.”
    Ah I didn’t realise that, I’ve never used anything other than Avid Xpress and FCP
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Herb Sevush
    January 12, 2012 at 6:52 pm
    [Bret Williams] “Avid was the first to make the source / record analog metaphor a standard. “
    On the Mac, yes, but the first, no.
    EMC came out on the PC at the same time as AVid and it also had a source / record GUI. Montage was earlier than either but I believe it was a single viewer interface.
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
