Activity Forums AJA Video Systems Thinking about an io…
  • Thinking about an io…
    Posted by Enzo Tedeschi on April 26, 2006 at 2:50 am
    Hey all,
    I’m thinking of picking up an io box, and was curious about hard drive recommendations. From what I read on other posts, a two-drive SATA raid would be enough – but will I need a third-party controller to get the speed?
    Any suggestions or ideas welcome, and I’m not shy about “rolling my own” if there is a significant advantage (in dollars or otherwise)…
    Also, has anyone experienced any major headaches with this box working at 1:1? And does it allow for say 2:1 within the codecs etc? It’s unclear from the AJA website….
    Thanks in advance…
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
    Enzo Tedeschi replied 20 years, 4 months ago 3 Members · 6 Replies
  • Bob Zelin
    April 30, 2006 at 4:46 pm
    a great SATA starter kit is the Firmtek Seritek 2 port host card, 2 bay SATA enclosure, with 2 Seagate or Hitachi SATA drives. This is VERY inexpensive, and will easily to 8 and 10 bit SDI and DVCProHD. Yes, you must stripe the 2 SATA drives together using Apple Disk Utility. I use this configuration all the time with zero problems. You will make back the money on this configuration the first day of billing.
    Bob Zelin
  • Enzo Tedeschi
    April 30, 2006 at 11:54 pm
    Thanks, Bob.
    I have done some pricing comparisons, and to build one as per your suggestion comes to within a couple of hundred dollars of something like this in the same size:
    https://www.streetwise.com.au/product_info.php?cPath=28_162&products_id=4602
    and this unit has the RAID built in. A wiser option? Built-in RAID surely must offer some advantage… plus I’m in Australia, and I can’t seem to fins a local supplier for the Firmtek stuff… yet…
    Do you have an opinion of the Lacie unit? Or Lacie in general – the views her are mixed.
    Enzo Tedeschi
    Editor
    Sydney, Australia
  • Mat @ lacie
    May 1, 2006 at 12:03 am
    Hello Enzo,
    If you are considering a SATA solution from LaCie, you can check out the Two Big:
    https://www.lacie.com/products/product.htm?pid=10490
    500GB or 1TB.
    Works great for 8bit/10bit SD.
    Hope this helps.
    Mat @ LaCie.
  • Enzo Tedeschi
    May 1, 2006 at 12:12 am
    Thanks, Mat.
    That’s the one in my link above – can’t buy from the Lacie store, as it won’t ship to Oz.
    Are they shipping yet? Everywhere online is listing them as pre-orders only.
    Enzo Tedeschi
    Editor
    Sydney, Australia
  • Mat @ lacie
    May 1, 2006 at 12:18 am
    Hi Enzo,
    We started to ship in the US a few weeks ago so I am fairly sure that LaCie Australia is also shipping Two Big. If not, it should be a matter of days.
    Just in case, here is LaCie Australia contact info:
    https://www.lacie.com/au/contact/
    Thanks.
    Mat
  • Enzo Tedeschi
    May 1, 2006 at 12:22 am
    Rock and roll, Mat.
    Enzo Tedeschi
    Editor
    Sydney, Australia
