Activity › Forums › DSLR Video › Think its time to get a super-zoom lense, advice please
  • Think its time to get a super-zoom lense, advice please
    Posted by Ben Edwards on July 31, 2012 at 3:02 pm
    Hi, I have a Canon 550D and the following lenses:
    – Canon EF 50mm f/1.8
    – Canon EF-S 17-85mm f/4-5.6 IS USM
    – Canon EF-S 55-250mm f/4-5.6 IS
    The 17-85 is the one I use the most and am quite happy with it, but as a lot of the stuff I do is run n gun so changing lenses can be a bit of a problem. I have been looking around at ‘superzoom’ lenses and the only ones with image stabilization seems to be (loking for something up to around £400):
    – Tamron AF 18-270mm f/3.5-6.3 VC
    – Canon EF-S 18-200mm f/3.5-5.6 IS
    – Sigma 18-200mm f/3.5-6.3 DC AF OS
    – Sigma 18-250mm F3.5-6.3 DC OS HSM
    Are there any I have missed? Also how are these likely to compare to my 17-85 in terms of picture quality and stabilization? (not too bothers about autofocus as I use manual). As 200 is 320 equivelent for cropped sensor maybe this is all I need/will be able to hand hold.
    All insight welcome;).
    Ben
    Ben Edwards – Freelance Picture Editor
    https://www.funkytwig.com
    Macpro1,1 2007 6GB RAM 2*2 3Ghz Xeon
    Ben Edwards replied 14 years, 1 month ago 1 Member · 1 Reply
  • Ben Edwards
    August 1, 2012 at 3:45 pm
    Thought I would provide a update. I think the Tamron 18-270 is the best bet. I posted this to the dpreview Third Part Lens Forum but as it is releven here I will also post:
    Hi, I have been looking for a superzoom and just read the reviews on this site for these two lenses. This topic has been covered before but as I shoot video the requirements are a little different. The two main differences for me are that autofocus is not used and the lens does not have to resolve such a high resolution (HD video is under 4 Megapixels).
    I have come to the conclusion that the Tamron is a better bet and not because of the zoom range (well not at the tele end). The review seems to indicate the Tameron gives better image quality/distortion (sharpness, barrel and chroma) at the wide end and with video it is the wide end that is generally more impotent. Tamron also seems to go a tad wider which is good.
    Interestingly the Tamron gets a slightly better score (alough obviously a single quantitative score for a lens is very crude and of limited use).
    Any thoughts?
    Ben
