Activity › Forums › Adobe After Effects › Thin white lines in after effects on eps
Posted by Fabrice Studer on October 1, 2019 at 9:51 amHey,
I’m working in after effects and when i import this eps, i get these very thin white lines.
Here’s a screenshot of a white line
13766_whitelines.jpg.zipthx for help
-fabrice
Fabrice Studer replied 6 years, 7 months ago 4 Members · 4 Replies -
Richard Garabedain
October 1, 2019 at 3:40 pmmy guess is it is just the image and not anything else…just no once noticed it until it was blown up…use the content aware fill tool..or clone brush in photoshop would be easier
Cassius Marques
October 1, 2019 at 5:10 pmThere is probably a white rectangle underneath a pink rectangle. AE algorithms may render that differently than the application that created it, so you’re seeing the result of the anti-aliasing/scaling/rasterizer. Which ever one that’s affecting that.
Cassius Marques
http://www.zapfilmes.com -
Eric Santiago
October 1, 2019 at 5:39 pmI’ve seen this in poor logo design.
I also experience this with so-called EPS vectors but turns out to be a pixel graphic embedded POS but doubt thats it. -
Fabrice Studer
October 2, 2019 at 8:16 amHey guys,
the image was fine, no white lines in the ai file or rectangles underneath it.
I figured out a workaround, i just duplicated the layer in ae and put the third option on the quality and sampling swith, the pixelated straight line. Now the lines are fone, since they are transparent.
I know this isn’t the smoothest solution, but i works for now.
I could imagine that merging all the layers in ai and creating a one layer graphic would maybe work too.
Thanks for the help guys
