Activity Forums Adobe After Effects thin vertical lines flickering, ach.
  • thin vertical lines flickering, ach.
    Posted by Rich Ramazinski on July 25, 2006 at 7:26 pm
    hey all-
    does anyone have any creative ways to deal with the way thin vertical lines flicker when moving across a composition space?
    I’m unable to change the image (or scale up in it). I’ve been attempting to use a kind of filter like “reduce interlace flicker” to deal with the problem, to no avail.
    any ideas?
    thanks for reading this.
    rich
    p.s. – in the old days wasn’t this problem called something like “moray-ing”?
    Rich Ramazinski replied 20 years, 1 month ago 3 Members · 4 Replies
  • Dan O’brien
    July 25, 2006 at 8:10 pm
    Are you talking about lines that appear when you’re ram previewing the comp? If so, you can try turning on frame blending for that layer. Also, I’m not 100% sure if this helps, but if the layer you’re talking about is video, make sure the source’s settings are all correct by right-clicking on the source in the project window and choosing “interpret footage>main”.
    Just a note, I sometimes get wierd vertical lines when previewing a comp that don’t actually effect the final render.
    Dan
    PrEditors.net
  • Rich Ramazinski
    July 25, 2006 at 8:25 pm
    dan-
    thanks for the post!
    no, the flicker is also on the final render.
    I’m animating images of old woodcuts (lotsa lines and crosshatching), and the problem occurs when the width of the lines are smaller than the pixel it occupies. So, when the image moves, AE keeps calculating a different color value.
    I can’t scale up to get rid of the problem.
    any ideas?
    thanks again.
    rich
  • Erik Pontius
    July 25, 2006 at 8:53 pm
    if they are stills you might experiment with adding a 1 pixel motion blur in the vertical with photoshop.
  • Rich Ramazinski
    July 26, 2006 at 5:17 pm
    yes, it look like I’ll be using some blurring and vignetting to hide the flickering as best as possible.
    thanks for the replies!
    rich
