Thin Vertical Bars I can’t get rid of on the side of my video
Hoping y’all can help me with a bit of a humdinger I’ve had on my hands. In some but not all sequences I work on in Premiere CC 2016, the canvas has appeared to widen by, I would guess, about five pixels. This is not the case, though – because when I pull up sequence settings, I can see that the project is in 1920 x 1080 (just like the footage I’m using,) and pixel aspect ratio is square.
My current problem sequence was duplicated from a sequence where this is not an issue, so my guess is that I’m accidentally – and frequently – creating the problem, but I can’t even figure out what the problem is. Whatever the issue is, I don’t believe it can be changed in sequence settings, as I’ve compared sequence settings from problem sequence and normal sequences and they are identical to each other.
There are a couple of short term solutions to this – scale all the material up to 101%, copy and paste everything into a new timeline – but I was hoping someone might know what I’m talking about, because this problem keeps popping up and I’d prefer to have a long-term solution.
