Activity Forums Adobe After Effects Thin lines in Trapcode 3D-Stroke
  • Thin lines in Trapcode 3D-Stroke
    Posted by Hans Meier on May 7, 2008 at 4:02 pm
    Hi everyone,
    is there any way to avoid those nasty “steps” when working with very thin lines (thickness around 0,5) with Trapcode 3D-Stroke.
    Screenshots
    100%
    Zoomed in
    Hans Meier replied 18 years, 4 months ago 4 Members · 6 Replies
  • Hans Meier
    May 7, 2008 at 6:56 pm
    Hi Dave,
    concerning Video I get your point, but I’m working for Computer-Display Output only. So I use square pixels and no interlacing …
  • Hans Meier
    May 7, 2008 at 7:18 pm
    Dave,
    thank you for your help and your explanation.
    One last time – here is my problem…it would look so nice without the steps. 🙁
  • Sascha Verwiebe
    May 7, 2008 at 10:45 pm
    setting the Feather value to 100 can help.
    you could also try to create 1px strokes in a precomp at double resolution, and scale it down in your main comp. maybe use subpixel positioning.
    as dave said, the steps will not go away, but it might get better than what you have now.
    sascha
  • Eric Lease
    May 7, 2008 at 11:59 pm
    Try upping the thickness of the line, then thin it back out with the Simple Choker effect. To get a line that is thickness 0.2, start with a line of thickness 1, apply Simple Choker at 0.65, then duplicate the layer to increase the brightness.
  • Jens Enqvist
    May 8, 2008 at 7:06 am
    Modifying the alpha gamma slightly can help.
    http://www.antigrain.com/research/gamma_correction/
  • Hans Meier
    May 8, 2008 at 7:47 am
    Dave,
    I really didn’t want to offend you! Sorry!
