Activity › Forums › Maxon Cinema 4D › thickness tool?
thickness tool?
Posted by Steve Brigantino on October 11, 2007 at 8:23 pmIs there an add tickness tool in C4D?
Other apps like, Hexigon, Carrara and Amapi Pro have.
Please and thanks
Nolan Scott replied 18 years, 11 months ago 3 Members · 4 Replies -
Nolan Scott
October 12, 2007 at 12:21 amWell, if you have a Circle-spline or any other spline-object,
just drag it into an Extrude NURBS (Objects / NURBS / Extrude NURBS),
and adjust the settings (Movement) in the Attributes-Manager.Cheers
Nolan -
Adam Trachtenberg
October 12, 2007 at 3:31 pmAnother trick is to use the ExplosionFX deformer’s Cluster/Thickness property (while turning off the exposion itself, of course).
Nolan Scott
October 12, 2007 at 8:15 pmWhat a marvelous technique…
always such a great pleasure to learn something new…Thank you very much
Cheers
Nolan
