Activity Forums Maxon Cinema 4D Thickness on animated Lathe
  • Thickness on animated Lathe
    Posted by Fabio Apelbaum on May 20, 2020 at 4:57 pm
    Hi guys, I have a spline animated at PLA level and putting it inside a Lathe. But a lathe object doesn’t have a thickness, so I added the thickness using a cloth surface and that did the trick, the problem Im having is that in some frames the extrusion jumps out of position not sure why… but I wonder if there is a different way to add thickness to a parametric object? Im using C4D 22.
    Thank you all!
    Fabio
    Jim Scott replied 6 years, 4 months ago 2 Members · 1 Reply
