Activity Forums Adobe After Effects Thickness of text responds to audio
  • Thickness of text responds to audio
    Posted by Jordy Veenstra on February 18, 2020 at 10:43 am
    Hi all,
    I am making a simple animation for a client where a piece of text responds to the bass of a song. The standard Audio Amplitude -> Expression to text property thing. Now I’ve been asked to do that effect on the thickness of the text. If there’s no bass, the text font uses the normal type, if there’s a lot of bass, the text font uses the bold type font. As there is no parimeter from scratch in AE’s text settings I presume I have to make this happen through expressions etc? Can someone help me with this?
    Thanks in advance!
    Jordy Veenstra replied 6 years, 6 months ago 3 Members · 4 Replies
  • Michael Szalapski
    February 21, 2020 at 10:24 pm
    The problem is that there’s no way to animate between font styles of a typeface. It would be just a hard cut between the two.
    If that’s what they want, fine. In the latest release of AE, you can control bold/italics/etc. with expressions, so you would use an if/then statement on the amplitude of the bass. (You would get that by either using Sound Keys from Red Giant to create keyframes from just the bass OR by going into Adobe Audition and isolating the bass and creating a new track from it and then running AE’s Convert Audio to Keyframes command.)
    Actually, I just had a thought, is the piece of text the same throughout the whole video? There might be a way to have it smoothly transition between a bold and normal font type, but it would be a massive pain if the text is changing frequently.
    Now, you could animate the thickness of the text’s stroke with AE’s normal text animators (driven by an expression) and get pretty similar results. The effectiveness of that technique would vary depending on your typeface, of course.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Chaz Chester
    February 22, 2020 at 2:23 pm
    Instead of switching between font weights, would it work to use the thinnest weight and have the stroke width animate? It would create the illusion of the font getting thicker.
  • Michael Szalapski
    February 24, 2020 at 6:44 pm
    It might work or it might not – depending on the font and the client requirements. But, if you look at my response, it was one of the things I suggested (last paragraph before the sig line).
    – The Great Szalam
  • Jordy Veenstra
    February 25, 2020 at 8:33 am
    Thanks all! Much appreciated. I think I’ll be able to suit the requirements with these options. Ill do some testing and get back to work. Thanks a lot!
