Activity Forums Adobe After Effects thickness in 3d space?
  • thickness in 3d space?
    Posted by Jos Willem on March 4, 2007 at 3:03 pm
    How can I create thickness in a object? I want to make a freeze frame from a person and after that the camera will rotate around the person.
    somthing like cardboard?
    Thanx
    Mylenium replied 19 years, 6 months ago 3 Members · 2 Replies
  • Nate Vander plas
    March 4, 2007 at 5:31 pm
    Check out the “common AE questions” near the top of this forum page in the sticky notes section. This has been discussed many times and there are some tutorials that you can find by a simple search.
  • Mylenium
    March 5, 2007 at 7:55 am
    You can’t – more or less. Pixels cannot be extruded. Like Nate said, if you do a search, you can come across some alternative techniques involving plugins mostly, but that’s pretty much it.
    Mylenium
    [Pour Myl
