Activity › Forums › Apple Final Cut Pro Legacy › thickening text
  • Chris Poisson
    August 22, 2007 at 6:17 pm
    If you just want to beef it up a little, open the file in Photoshop, select the alpha channel and go to selection, modify, expand, and set it to 1 or 2 pixels, then re-save the selection as the alpha channel. Of course, you should do a save as, so you keep your original file. This will beef it up, wether you like it is another matter.
