Activity › Forums › Adobe InDesign › These Damn Tabs! Automatic First Line Left Indent
  • These Damn Tabs! Automatic First Line Left Indent
    Posted by Gordy Grundy on June 13, 2018 at 2:00 am
    Thanks for your help!
    Laying out a simple novel. I import text from Word and paste it in. The first sentence of each paragraph is indented at .5″ This is automatic. Note: Under the Paragraph settings, the First Line Left Indent is set to 0.
    How do I change that First Line Left Indent to be .25″, not .5″?
    I’ve checked everything and read Adobe manuals, but I have not found a solution.
    Many thanks!
    Gordy Grundy replied 8 years, 3 months ago 2 Members · 3 Replies
  • Gordy Grundy
    June 13, 2018 at 2:17 am
    Note: I have CS3
  • Kalleheikki Kannisto
    June 14, 2018 at 7:08 am
    Step One: Don’t copy-paste Word documents into InDesign, they come with too much garbage. Import them instead, which cleans out most of the unnecessary formatting.
    Step Two: If that alone doesn’t handle it, use the Remove Overrides button on the Paragraph Style palette.
    Step Three: If the problem persists, create a whole new paragraph format with the desired formatting, apply “none” and then the new formatting.
    Senior Graphic Designer
  • Gordy Grundy
    June 14, 2018 at 5:49 pm
    Thank you KK. I will dig in!
