Activity Forums VEGAS Pro There’s got to be a way to…
  • There’s got to be a way to…
    Posted by Jake Zeer on February 21, 2006 at 11:30 pm
    It must be possible to select a few clips on the same track and then make them all the same duration without having to shrink or expand each individual clip. For example – I have 4 different clips with transitions in between and I want it to be smooth so I want the duration of each clip to be equal. How can I accomplish this??
    Thanks for the help in advance
    Jake
    Edward Troxel replied 20 years, 6 months ago 2 Members · 3 Replies
  • Edward Troxel
    February 22, 2006 at 2:23 am
    Look at scripting! I use the Duration tool in Excalibur for this purpose. However, I’m sure you can find many other scripts out there that can do this. In fact, here’s one for you: https://www.jetdv.com/vegas/forum/viewtopic.php?t=389 but you’ll have to manually edit the script to set the proper length.
    Edward Troxel
    JETDV Scripts
  • Jake Zeer
    February 22, 2006 at 7:44 am
    Amazing!!!!!!! You saved me hours of work.
  • Edward Troxel
    February 22, 2006 at 2:47 pm
    Scripts are your friend 🙂
    Edward Troxel
    JETDV Scripts
