Activity › Forums › Boris FX Particle Illusion › There is some lib to do this?
Posted by Khrysller on August 10, 2006 at 1:37 pm@ 00:09 to 00:11 seconds in https://awm-media.tm73.com/AWM%20Demo%20Rough1Mbps_Stream.wmv …that white line rounding the place..
posted here:
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=173&postid=855918thanks : )
Khrysller replied 20 years ago 4 Members · 7 Replies -
Alan Lorence
August 10, 2006 at 5:37 pmYou can get something similar using a “trail” emitter, but it won’t be exact. You can make one of these emitters by setting velocity to 0, increase number to a pretty high value, then draw the emitter path. Probably looks best if you use a shape image that slightly long and thin, and angle it at 45 degrees or so. You may want to use the size over life graph too.
Alan.
wondertouch -
Elvis Deane
August 10, 2006 at 7:09 pmI made some attempts at a similar effect a looong time ago (the request that time was for streaks like the ones Trapcode’s 3D Stroke makes). I never got it quite right, but you can check out the project file here. By adding some high quality motion blur, it may end up looking pretty good.
Elvis Deane!
The Apprentice Magician’s Guide to particleIllusion
Alan Lorence
August 11, 2006 at 5:10 pmIt’s not an effect that you can do easily with particles. You’re trying to make a very smooth line with many small dots. Not the best way.
Alan.
wondertouch -
Khrysller
August 11, 2006 at 5:19 pmThis is good in some point…
what is missing to make PI possible to do this in a easy form?maybe this ‘thing’ could allow ways to do a LOT of other kinda of effects in PI.. of course without leaving the PI focus.
it
Tony Mueller
August 18, 2006 at 9:32 pmHi there,
I’m the guy who’s guilty of posting that demo reel… I made those strokes based on this tutorial:https://www.creativecow.net/articles/velez_dean/glowing_stroke/index.html
Khrysller
August 18, 2006 at 10:18 pmWOW nice… gonna follow this and try after…
thanks for reply dude…
i really enjoy what u have done : )
