Activity › Forums › Apple Final Cut Pro Legacy › There is no Apple ProRes option in Mpeg Streamclip
  • There is no Apple ProRes option in Mpeg Streamclip
    Posted by Zachary Moore on January 6, 2012 at 6:20 pm
    I’ve been having an issue with FCP 6, and I’ve finally reached the limits of my googling abilites.
    I shot my footage on a Canon 5D, and I imported it directly into FCP. Unfortunately, the footage is incredibly choppy and difficult to edit. However, I had a deadline, and I just worked with what I had.
    Now that I have some free time, I’ve been trying to figure out the solution to this problem. I moved the footage over to a newer, faster external harddrive (lacie 500gb w/ Firewire 800). Same issue. I did some more research, and it seems like this is a common issue with footage from the 5D. Someone on another forum suggested that the solution would be to convert the files into Apple ProRes 422, and to change the audio settings to 48 khz. So I put one of the files into mpeg streamclip, and I discover that there is no Apple ProRes 422 option.
    After googling some more, I discovered that the ProRes codec only comes with FCP. Which is great, except I have Final Cut Pro installed on my computer already.
    So, tl;dr if anyone knows why I wouldn’t have the Apple ProRes 422 codec installed on my computer even though I have FCP, that would be great.
    Also, if anyone knows the solution to my main problem (choppy footage from the 5D) that would be equally helpful.
    Morgan Dirven replied 10 years, 1 month ago 10 Members · 13 Replies
  • 13 Replies
  • John Fishback
    January 6, 2012 at 6:37 pm
    You are correct in wanting to convert your 5D footage to ProRes. I’m not sure why MPEG Streamclip doesn’t see the ProRes codec. Try Repairing Permissions or better yet run DiskWarrior then Repair Permissions. Have you tried Compressor? Be sure to turn on Frame Controls and adjust the quality settings. That will produce an excellent transcode.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • David Roth weiss
    [Zachary Moore] ” I moved the footage over to a newer, faster external harddrive (lacie 500gb w/ Firewire 800). Same issue.”
    Of course, the problem is that FCP can’t properly decode and encode MP4 footage, which has little or nothing to do with system overhead or hard drive throughput. Editing MP4 and h.264 footage simply didn’t make the cut when the developers ceased updating FCP and stared work on FCPX.
    [Zachary Moore] “Someone on another forum suggested that the solution would be to convert the files into Apple ProRes 422, and to change the audio settings to 48 khz. So I put one of the files into mpeg streamclip, and I discover that there is no Apple ProRes 422 option.”
    Sure there is… You evidently didn’t take the time to learn Streamclip or to read the manual.
    Load a clip into Streamclip, choose File>>Export to Quicktime, then change the Compression drop-down to ProRes 422.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Steve Eisen
    January 6, 2012 at 6:49 pm
    Zachary
    I’ll put you up to another test. You have to do this on your own since you have some free time. It’s also the best way to learn. Search for Tapeless Workflow with Final Cut 7 by Shane Ross. Even though you have FCP 6, this will still work for you. There is an easier way to get footage from your 5D into FCP without using MPEG Streamclip.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Shane Ross
    January 6, 2012 at 6:56 pm
    I’ll provide the link to that tutorial….
    Tapeless Workflow for FCP 7 Tutorial
    (You guys need to bookmark it or something. 🙂
    Shane
    Little Frog Post
  • Steve Eisen
    January 6, 2012 at 7:50 pm
    You’re too nice Shane!
    I have it bookmarked.
    Steve Eisen
    Vice President
  • Zachary Moore
    January 6, 2012 at 7:51 pm
    Thanks everybody! David Roth Weiss was correct, I was using Mpeg streamclip incorrectly. I did it the way he suggested with one of the clips and it seems to have solved the issue.
    And I definitely will check out that video, probably as I wait for Streamclip to convert the files.
  • Ted Hesson
    March 27, 2012 at 3:05 pm
    Hi David-
    Should MPEG Streamclip still show the Apple ProRes 422 codec option if I’m using Final Cut Express? Last week I was using FCP in another office and when I converted in MPEG Streamclip, the ProRes codec was an option. But now that I’m on my work computer (which has Final Cut Express), I don’t see the ProRes codec listed as an option. I settled on trying Apple Intermediate but I’m not sure what that will do to the video. I’m shooting with a Canon G12.
    Thanks, help from anyone out there is appreciated. I guess the simple solution is to buy FCP 10.
  • Eric Rosenfeld
    November 18, 2013 at 3:21 am
    That didn’t work for me. I didn’t get the “Apple Pro Res 422” as an option in the dropdown list for compression in MPEG Streamclip when I did that. Does that mean I just don’t have it on my computer? I use iMovie 6 on a 2007 MacBook Pro. I don’t have Final Cut Pro.
  • Wes Tabayoyong
    February 6, 2014 at 3:06 am
    I also just downloaded MPEG Streamclip – and it does not have ANY ProRes options when you select QuickTime.
    Is there an older version that does?
    Is there a different version that does?
    Is it no longer an option?
  • David Roth weiss
    February 6, 2014 at 5:47 pm
    [Wes Tabayoyong] “I also just downloaded MPEG Streamclip – and it does not have ANY ProRes options when you select QuickTime.”
    Like all QT enabled apps, Pro Res encoding is not actually part of the app, it’s made possible by the installation of QT on the computer that either done manually or automatically, such as when you install FCP.
    So, what OS are you running? What version of QT? Do you have FCP installed on this computer? Is it a Mac or a Windows machine?
    David Roth Weiss
    ProMax Systems
    Burbank
    DRW@ProMax.com
    Sales | Integration | Support
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
