Activity Forums Adobe After Effects There is animation but no visible keyframes
  • There is animation but no visible keyframes
    Posted by Mohsin Khan on July 16, 2017 at 5:56 am
    I have recently downloaded an after effects project for stomp typography. I can see the animation going on but when I press U, there are no keyframes visible. Also there are many effects on all the layers but they aren’t visible under effects control tab. What am I missing here. I want to know about it and how can I reveal the keyframes and the effects,
    Remus Hosu replied 9 years, 1 month ago 3 Members · 2 Replies
  • Walter Soyka
    July 17, 2017 at 1:59 pm
    U should show properties with keyframes, but with precomposing, parenting, and expressions, you could miss a lot. UU will show all properties which have been modified from their defaults. This will at least include properties with expressions, but not keyframes.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Remus Hosu
    July 18, 2017 at 9:53 pm
    Most likely they have no keyframes but expressions. You can press EE to bring down the expressions
    On another note, if you’re intersted in placing the text layers on a motion path, there’s a trick to reveal the “invisible” keyframes. See the tutorial here:
    https://bluefx.net/capture-invisible-keyframes-motion-path-shape-layer
    https://bluefx.net
