Activity Forums Adobe Media Encoder There are artifacts in our Encore Build
  • There are artifacts in our Encore Build
    Posted by Jay Stein on February 20, 2012 at 12:42 am
    Help.
    I’m sort fo a newbie, so please forgive me if I am not doing this right.
    I poste and have not heard from anyone.
    We built an ENCORE file from a QT MASTER (895 gigs) which was originally exported from a FCP MASTER.
    In the ENCORE “BUILD” there are white specks and black specks/artifacts, particularly where there is a higher level of bright light. i.e. when a headlight shines on someone’s face.
    These issues appear in the exact same spots every time. We burned a Blu-ray disc and they appear in the exact same spots as well. So I don;t think the issue is related to the cables or TV (because it is in the ENCORE BUILD as well)
    NOTE: 4 weeks ago, we had previously performed the exact same process, using ENCORE, with the same Blu-Ray burner and there were NO issues whatsoever. Since then we have added about 2 minutes of footage (including a 10 second green screened sequence) to the master FCP MASTER, which looks great (no artifacts) then exported to a QT Master, which also looks great (no artifacts), then built it on ENCORE. Now we have this issue with the specks/artifacts.
    ALl fo this said, there is a possibility that the first build in ENCORE was from a PRO-RES Master (only 95gigs). Don;t think so, but need to check it out.
    Anyone have any answers and/or solutions?
    Jay Stein replied 14 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
