Activity › Forums › AJA Video Systems › theoretically and practically question
  • theoretically and practically question
    Posted by Ismet Arnautalic on December 18, 2011 at 1:51 pm
    Is it possible to convert SD video from 4:3 to SD 16:9 without squeezing pictures? (loosing part of pictures on top and bottom)
    If it possible, how to do it with Kona 3
    If it is not possible:
    Can I decide which part of picture I must loose. I prefer bottom part.
    Any help
    Regards
    Ismet Arnautalic replied 14 years, 9 months ago 2 Members · 2 Replies
  • Shane Ross
    December 19, 2011 at 7:51 am
    [Ismet Arnautalic] “Is it possible to convert SD video from 4:3 to SD 16:9 without squeezing pictures? (loosing part of pictures on top and bottom)”
    Not really. How can you take the 4:3 space…and make it 16:9 without stretching it…or cutting off the top and the bottom? How can you do that? Make a square into a rectangle without changing it’s shape?
    [Ismet Arnautalic] “If it is not possible:
    Can I decide which part of picture I must loose. I prefer bottom part.”
    You’d have to capture as Pillarbox, and then manually blow up the picture the last 33%, and pan and scan it.
    Shane
    Little Frog Post
  • Ismet Arnautalic
    December 19, 2011 at 1:12 pm
    Thank you Shane very much. Now it is much clear for me. I think computer can make everything.
    Regards
