Activity Forums Avid Media Composer The Xpress DV to Xpress Pro process
  • The Xpress DV to Xpress Pro process
    Posted by Eric Anderson on August 24, 2005 at 6:47 pm
    I am a new Avid user who has been working with FCP for years. I’m not familiar with how the various versions of Avids play with each other.
    The company that I work for just got Xpress Pro but I want to make sure the current projects in progress that were cut with Xpress DV will transfer ok.
    Are there any extra steps I will need to take to load the DV projects in Pro or will they show up automaticly and load after I install Pro?
    I will also be upgrading the OS from 10.2 to 10.3.9
    Thanks for the help!
    Samuel A. martin replied 21 years, 1 month ago 3 Members · 4 Replies
  • R Lague
    August 25, 2005 at 5:26 am
    biggest difference is that DV will handle 8 audio and 8 video tracks on the timeline. Pro will handle 24 of each.
  • Eric Anderson
    August 25, 2005 at 3:56 pm
    But will my project that I did in DV open in Pro or will I have to convert it somehow?
  • R Lague
    August 25, 2005 at 4:21 pm
    It will open if you settings are the same and your audio rate is the same and you don’t have over 8 tracks.
  • Samuel A. martin
    August 26, 2005 at 6:33 am
    Make sure you go onto your project bins and before opening the project on Xpress pro you delete the settings file. Otherwise you might expereince problems on Xpress pro every time you open that project. Once deleted you start Xpro, Xpro will create a new settings file.
