Activity Forums Apple Final Cut Pro The x264 open source alternative to the H.264 Apple encoder
  • The x264 open source alternative to the H.264 Apple encoder
    Posted by Dave Gage on November 15, 2011 at 10:25 pm
    Since 100% of what I do goes to the web, encoding quality and file size is a big deal to me. My recent tests with the open source x264 QT Component have been pretty impressive–same or better quality of H.264 with almost half the file size. I’ve used it with QT 7 and Compressor 3.5.3 on exported Pro Res 422 files from FCP X and ScreenFlow 3.
    Any way, I’m essentially sharing and/or seeing if anyone has prior experience and any suggestions for preset tweaks.
    General Info:
    https://realworldvideocompression.com/rwvc/2010/5/7/using-x264-plugin-in-compressor.html
    https://www.youtube.com/watch?v=JSfirGa-Dvg
    Download:
    https://www.macupdate.com/app/mac/24173/x264encoder
    or
    https://www003.upp.so-net.ne.jp/mycometg3/
    (“In order to take advantage x264, let’s start by installing the plug in. Download the Disc Image and launch it. Copy the file x264encoder.component to YourComputer>Library>QuickTime and restart any open applications that use QuickTime.”)
    “x264 forms the core of many web video services, such as Youtube, Facebook, Vimeo, and Hulu. It is widely used in television broadcast and by ISPs.”
    Dave
    Ht Davis replied 11 years, 7 months ago 6 Members · 7 Replies
  • 7 Replies
  • David Lawrence
    November 16, 2011 at 2:50 am
    Hi Dave,
    Thanks for posting this. I’ve been using x264 for most of my client deliverables for about a year now and love the quality. So do my clients! Hoping to write up an article with full workflow and settings as soon as I can clear my schedule.
    _______________________
    David Lawrence
    art~media~design~research
    propaganda.com
    publicmattersgroup.com
    facebook.com/dlawrence
    twitter.com/dhl
  • Jeremy Garchow
    November 16, 2011 at 3:10 am
    x264 gets high praise over on Reduser all the time.
  • Erik Lindahl
    November 16, 2011 at 11:29 am
    x264 beats more commercial h264 encoders oddly. Apple Compressor (which I’d say is probably the worst of the pack) and Episode (which is reliant on MainConcept to some degree) give far worse results. I can highly recommend this also.
    Erik Lindahl
    Freecloud Post Production Services
    http://www.freecloud.se
  • Dave Gage
    November 16, 2011 at 6:11 pm
    David, Jeremy, and Erik,
    Thanks for the replies. With all the success of this encoder I’m surprised I wasn’t initially able to find out more about it before I installed it. (Most the of the posts and references to it seemed to center around how to properly install and use with Windows.)
    David, if you or someone can put together a comprehensive tutorial of it’s use, I think that would be a great boon to the web-video community.
    A use tip that someone may find handy is that when you go into QT 7 and select “Movie to QuickTime Movie” and then Settings: Compression Type: x264encoder, the default file extension is .MOV. Since I need .MP4 files (or .m4v) for my Flash video player (so I can use an HTML5 fallback for iPhone and iPad users as .MOV files seem oddly not so compatible with Apple mobile devices), I was a bit worried that it wouldn’t give me what I needed. But, I did find somewhere on the web that if you type in the .MP4 extension to the file name before hitting “Save”, the encoder is smart enough to create that file type. Pretty cool.
    Also, I did try some of the Andy Beach tweaks in the “Options…” settings tabs, but ended up just going with the default “Component Default” preset. I did though choose the “use 3rd pass” option on the Behavior tab which hopefully gives a slight increase in the quality. The vast majority of the option choices are above my head, so I essentially just left them alone.
    Dave
  • Rafael Amador
    November 17, 2011 at 5:34 pm
    [Dave Gage] “A use tip that someone may find handy is that when you go into QT 7 and select “Movie to QuickTime Movie” and then Settings: Compression Type: x264encoder, the default file extension is .MOV. Since I need .MP4 files (or .m4v) for my Flash video player “
    HndBrake can export x264 as MP4.
    the only issue is that doen’t import Prores.
    You need to convert it first to 10b Unc.
    No generation lost but an annoying extra step.
    [Dave Gage] ” I did though choose the “use 3rd pass” option on the Behavior tab which hopefully gives a slight increase in the quality.”
    With QT/H264, “Multipass” already means three passes.
    Seems that with this component is different.
    rafael
    http://www.nagavideo.com
  • Dave Gage
    November 19, 2011 at 6:45 am
    Rafael,
    [Rafael Amador] “With QT/H264, “Multipass” already means three passes.
    Seems that with this component is different.”
    I didn’t know that. It seems that as much or more emphasis is put on the speed of the x264 conversion as on the ultimate quality. I didn’t see much quality difference between the x264 default 2-Pass and the 3-Pass, but even the 3-Pass seems fast enough for me.
    Dave
  • Ht Davis
    January 25, 2015 at 2:40 am
    Standard set is yuv422, but x264 uses both luma and chroma compression with yuv420. You need CoreVF filters to prevent this from shifting the gamma. You need to specify this in your command line. It needs to Convert and then Tag the file so it appears with proper gamma settings (a reconversion on the fly). This gives better compression of data, but lesser color quality, rather than lesser detail quality. By not compressing the detail, it is retained with few artifacts, but the color is shifted. If you use a tagging VF filter, that essentially applies a metatag filter for the luma and chroma on the fly, you get better video compression and the right color. You just have to know your settings and be able to implement them. The latest quicktime component for mac is compatible with this, but I’m not sure about the windows components.
