Activity › Forums › Adobe After Effects › the vdeo is streching everytime
  • the vdeo is streching everytime
    Posted by Pasha Kulak on April 18, 2008 at 7:37 pm
    hello i have a question iv shot a video for a client in widescreen and after iv applied color correction and exported it it becomes a regular format stretched out i use ae and vegas the compositio settings are widescreen in both programs those are the shots
    pictures:
    ae export:
    https://i30.tinypic.com/11kgxnb.jpg
    vegas export:
    https://i32.tinypic.com/2le2su1.jpg
    btw whe i import the same file that havent been renderd yet in ae into vegas the stretching seems alright
    im prety sure im not rendering in a correct aspect ration from after effects…any help?
    thanks
    pk
    Curious Turtle replied 18 years, 5 months ago 3 Members · 6 Replies
  • Brian Berneker
    April 19, 2008 at 12:39 am
    The black bars on the side suggest that you are setting the project to widescreen but not the clip itself. I’m not too huge on my vegas, but see if there is a clip properties you can adjust. Just because the file is shot widescreen, doesn’t mean the app always knows that automatically… look for pixel aspect ratio or 16:9 etc.
    Brian
  • Pasha Kulak
    April 19, 2008 at 1:04 am
    i know how to do that in vegas but its not correcting the ratio its just stretching the video to fill the black bars and the video looks terrible…im pretty sure im not rendering the video right from after effects…this is vegas cant correct the video
    any help?
  • Brian Berneker
    April 19, 2008 at 4:21 am
    I wish I were more fluent in Vegas to give you the proper answer, but I often run into a similar problem with Final Cut Pro. After some digging, I found there was an aspect setting in the clip bin properties that allowed me to correct it properly (I believe it was actually a response to a post on the forums here). That’s why I’m suggesting you find the similar setting in Vegas.
    The other (probably improper) way I used to get around it before that was by opening the clip in Quicktime, pressing command-J (CTRL-J in windows I guess) and going to the visual settings tab of the video track and manually setting the scaled size to 854×480 and resaving. This wasn’t a flawless solution but it got me some headway at least…
    Not suprisingly, when using AE rendered files in Premiere it recognizes the aspect perfectly.
    Brian
  • Curious Turtle
    April 19, 2008 at 5:52 am
    If you do a screengrab of your output module, it might help diagnose the problem.
    Cheers,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Pasha Kulak
    April 19, 2008 at 9:35 am
    this is the composition settings in after
    Preset: pal d1/dv widescreen
    width: 720
    hight: 576 lock aspect ration to 5:4 is on
    pixel aspect ratio: dv pal widescreen 1.42
    vegas composition settings:
    preset : pal dv widescreen
    width: 720
    hight: 576
    pixel aspect ratio: 1.4568 (pal dv widescreen)
    i hope this helps
    i really need to understand this quick cause i ruined the whole workflow now and wont make a deadline
    thank you so far people
  • Curious Turtle
    April 20, 2008 at 6:04 am
    It sounds like you’ve got the right settings to go out from After Effects.
    Once you have the clip in Vegas, check out its Clip Properties setting and change the Pixel Aspect Ratio there to match the PAL Widescreen.
    It’s been a looong while since I dabbled with Vegas, so you may have to drop the clip back on the timeline again to see the change.
    Good luck,
    Ben
