I’d also check voice, just in case you hear some abnormalities in the voice quality. We regularly feed our PSC M4 to our EX-3 and Ex-1 and have our receivers set at Minus 30, and generally ( I know this will sound a little “canned” but set the volume control at 5) and it’s perfect. You mixer settings will determine where you set your transmitters, if they have a setting at all. In the camera I generally will set the audio level to about 2-3 marks above(to the right of) the 4:3 frame indicator if that’s any help.
jw
Producer/DP, HD series, “Discoveries…America”, “Discoveries…Ireland”, “Discoveries…Spain”,
“Discoveries…Argentina”, Discoveries…India”, “Discoveries…Asia”, “Discoveries…Africa”
