Activity Forums Adobe Photoshop the shortcuts to load highlights or shadows as a selection ?
  • the shortcuts to load highlights or shadows as a selection ?
    Posted by Marek on October 27, 2005 at 6:30 pm
    Hi All
    I have seen a video tutorial on Photoshop in which they use the shortcut to load highlights as a selection.
    What I’ve heard is : “command alt tilde … something like this ,
    Does it still exist in Phothop CS2 ? I can’t succeed by myself 🙁
    How is it possible to achieve it in a different manner ?
    Thank’s in advance 🙂
    Marek
    Jim O’meara replied 18 years, 3 months ago 3 Members · 4 Replies
  • Richard Harrington
    October 27, 2005 at 7:01 pm
    Select Color Range
    then hIhglights or Shadows
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Marek
    October 27, 2005 at 7:41 pm
    Richard,
    fantastic, in all day there is something to discover in digital darkrom , thank you very much:-)
    Marek
    October 27, 2005 at 8:54 pm
    Your welcome.. I use that command a lot… also be sure to try out shadow highloights command
  • Jim O’meara
    May 29, 2008 at 5:13 pm
    I know this post is old and your project is well over and done with but I thought I would add a small bit for others coming across it in their future searches.
    The Command + Option + tilde(~) (Control + Alt + tilde on the PC) that you mentioned in your post will load luminosity which looks at the brightness of the pixels rather than the highlights of the image. It will give a different result than loading the highlights, so it all depends on what you are after. I don’t know of another way besides the keyboard shortcut to do this.
    I use load luminosity and then select inverse to extract subtle shadows.
