Activity Forums Apple Final Cut Pro Legacy The selected window layout does not match…
  • The selected window layout does not match…
    Posted by Martin Nelson on November 16, 2010 at 10:33 pm
    I have four custom layouts (Window>Arrange) I cycle through all day long. One arrangement blows up the Canvas to the size of one of my monitors, one the Viewer, one lays out to a standard two-monitor configuration and one, well, I don’t use the fourth one much so never mind.
    Anyway, I’m cutting along happily all day, switching from one layout to another just fine and then, just now, I hit one of the shortcuts to switch the layout and I get:
    The selected window layout does not match your display configuration. Would you like to continue using it anyway?
    If I click OK then my monitors rearrange to the desired layout exactly as they should, but this message pops up every time. I have not changed my Monitor Display resolutions in the System Settings nor have I knowingly done anything else to cause this. My monitors display as they have always.
    I suppose I could trash these settings and create them over again, but what I’d really like is to know what caused this so I can prevent it from happening again. Is there a shortcut I might have hit unintentionally that could have affected my display configuration? Something else?
    Martin
    2 x 2.26 Ghz Quad-Core Intel Xeon
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
    Avid Media Composer 4.0.2.20
    Martin Nelson replied 15 years, 9 months ago 1 Member · 1 Reply
  • Martin Nelson
    November 17, 2010 at 6:33 pm
    I figured this out and thought I’d share.
    At some point yesterday I must have accidentally used the key combination of OPT+CMD+D. This turns on or, in my case, off Dock Hiding. I typically keep the Dock hidden and my custom layouts use up all of the monitor space. When I turned off Dock Hiding my custom layouts could no longer fit in their configured space and so I received the message.
    User erringly,
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
