Activity Forums VEGAS Pro the scrolling end-titles flicker: one field missing?
  • the scrolling end-titles flicker: one field missing?
    Posted by Walter Smith on February 14, 2007 at 2:13 pm
    (I am running Vegas 6.0d on WinXP SP1. I am using Xvid 1.1.0, Koepi’s build.)
    I am rendering the scrolling end-titles for my project. When using Xvid, the rendered video presents a substantial flickering. The same end-titles render very smooth using WMV9 (WinXP’s default codec).
    Here is an example:
    – with Xvid (2.7MB)
    – and with WMV9.wmv (976KB)
    I thought it was an Xvid issue, so I asked at forum.doom9.org. I was told this:
    Whatever tools you have used for encoding: The sources have been treated differently:
    – When feeding the source to WMV9 encoding, it was done correctly (no deinterlacing, the source is progressive).
    – When feeding the source to XviD encoding, the progressive source has been deinterlaced by discarding one field & doubling the height of the kept field.
    It’s the field discarding that is causing the flickering. Xvid has nothing to do with that – the error happened before Xvid did even get its fingers on the source.
    The first thing I thought was that “Field order” would fix things, but changing that option didn’t improove things. The man who replied wasn’t using Vegas, so he/she can’t tell me how to fix this. He/she insists thought that there is one field missing.
    What can I do to prevent the flickering?
    Walter Smith replied 19 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
