Activity Forums Adobe After Effects The Rotobrush Tool is the Devil!!!
  • The Rotobrush Tool is the Devil!!!
    Posted by Vladimir Lester on December 27, 2015 at 4:38 pm
    So, I have a clip at 24 FPS that i drag into after effects. Just like the tutorials, I duplicate it, drag the second copy on top, double click it to get to the “layer” window to rotoscope, grab the rotobrush and it tells me i need to set the composition frame rate to 23.976. Okay, cool. I set the composition to 23.976 and to my horror, as i grab the rotobrush again, the top layer (duplicate copy of the footage) all of a sudden doesn’t line up with the original! (AKA the duplicate footage layer is scooted down a bit) What is this? So, being experimental, I changed the composition back to 24 FPS and the interpret footage as well, and it is still happening!
    SOMEONE FRICKIN HELP.
    NO ONE SEEMS TO KNOW THE ANSWER.
    I NEED A GENUIS!
    Vladimir Lester replied 10 years, 7 months ago 54,536 Members · 4 Replies
  • Vladimir Lester
    December 27, 2015 at 9:10 pm
    Pretty much everything you just said, I’ve already done and explained that in the original post. I did the “interpret footage” thing already. But here is what the problem is, I’m using dynamic link, so it’s not as easy as just dropping the clip in after effects, I come from premiere pro and choose “replace with after effects composition” and it opens AE AND creates a comp for me. I then go into the side panel and go to interpret footage” menu. So I guess my question is “Are you then asking me to after going to “interpret footage”, to then REOPEN and the drag the footage again?
  • Vladimir Lester
    December 29, 2015 at 6:47 pm
    How do I accomplish that?
  • Vladimir Lester
    December 29, 2015 at 8:41 pm
    How do I remove the pull down?
  • Vladimir Lester
    January 10, 2016 at 1:02 pm
    Okay… So I’m guessing you don’t know how to do it? I just need help in figuring out how to do it?
