Activity Forums Adobe Premiere Pro The Quicktime frame rate bug still a thing it seems
  • The Quicktime frame rate bug still a thing it seems
    Posted by Tero Ahlfors on December 5, 2013 at 5:40 am
    I wrote about it before but this is still around:
    – I have a sequence I need to add black to.
    – If I use Premiere’s own generators, a still image or leave the track blank, Quicktime player will see some really weird frame rate on the exported Prores file. I exported as 23,976 and QT said it was 21,16.
    – This won’t happen If I render some black out of AE as a video file and use that.
    The files seem to be OK if I bring them back to Premiere, but I’ve gotten files back from broadcast clients who use a system that probably sees what QT would see in the file.
    Tero Ahlfors replied 12 years, 9 months ago 4 Members · 5 Replies
  • Chris Borjis
    December 5, 2013 at 6:57 pm
    I just exported a prores file on a mac using premiere black for
    the very end for a few seconds.
    the sequence and exported file are both reading as 29.97
    on a similar note, if I didn’t use premiere black and just
    extend the work area to be black, then export or queue with media encoder
    it refuses to have the extra black on the end now, which it never
    did before.
    now I have to add black if I want it included at the end of an exported file….weird.
    running CC october update
  • Chris Harlan
    December 6, 2013 at 6:11 am
    Interesting. Out of curiosity, have you tried the same things with other CODECs?
  • Tero Ahlfors
    December 6, 2013 at 8:40 am
    I can repeat that error all day long with Prores. MXF files and H264 work fine, although I can only check the H264 files in QT.
  • Tim Kolb
    December 6, 2013 at 2:53 pm
    You may want to check the H264 files in VLC…and, for the record, are you exporting H264 files with QT wrappers or as mp4?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Tero Ahlfors
    December 6, 2013 at 8:33 pm
    The problem is with Quicktime somehow seeing a crazy framerate. H264 mp4s render correctly and show the correct frame rate in QT player.
