Activity Forums Adobe Premiere Pro the project cannot be loaded it may be damaged….
  • the project cannot be loaded it may be damaged….
    Posted by Ryan Christensen on October 27, 2012 at 5:11 am
    I am using Premiere CS6 on a Macbook Pro and am in the middle of editing a huge project. I went to open the project today and got this error.
    “the project cannot be loaded it may be damaged or contain outdated elements”
    I have no idea how or why this is happened.
    PLEASE HELP!
    What I have tried:
    1. Starting a new project and importing the entire project. I get the same error message.
    2. Starting a new project and importing just the sequences. Premiere just stalls.
    3. Cleaning the Media Cache.
    4. Uninstalling then re-installing Premiere.
    5. Importing the project into After Effects. I get an error message.
    6. The auto-save files open, but the latest one is quite old.
    7. Duplicating the project file.
    8. Moving the project file and file structure to a new directory.
    None of these have worked!
    Any other ideas?
    Ryan Christensen replied 13 years, 8 months ago 3 Members · 5 Replies
  • Bala Chandran
    October 29, 2012 at 5:01 pm
    Silly questions:
    Did you save a COPY that you could try?
    Did you try any of the latest from the AUTO SAVE folder?
  • Ryan Christensen
    October 29, 2012 at 10:48 pm
    Thanks for the message:
    1. No. I did not save a copy. When I copy the existing project file and even rename it or put it in a new directory I get the same error message.
    2. The auto-saves do work! The problem is I was super aggressive with manually saving the project, so the last auto save is from way earlier in the day… thus loosing 1/2 day of great editing work.
  • Bala Chandran
    October 30, 2012 at 2:16 am
    Saving with a different name may not help if the project is damaged. So it is not the name or the directory. Probably did not save properly last time.
  • Trevor Ward
    January 7, 2013 at 4:15 pm
    Auto Save is sh#$. Auto save SHOULD function to automatically save versions of the file regardless of manually saving. I, like Ryan, save OFTEN. I’m having the same problem and now I’ve lost a full day of work. Painstaking work that won’t be any faster the 2nd time I do it. I HATE PP! It is NOT a professional grade software package.
    Ryan, did you ever figure out a solution?
    -Trevor Ward
    Red Eye Film Co.
    http://www.redeyefilmco.com
    Orlando, FL
  • Ryan Christensen
    January 7, 2013 at 4:21 pm
    Hi Trevor,
    Unfortunately I never did. I tried everything. To their credit, Adobe contacted me and helped me as well. They looked at the project file and indeed it was unrepairable.
    Ultimately I had to re-build my work off of the last autosave.
    Ryan
    https://www.bristleconemedia.com
