Activity › Forums › Adobe Premiere Pro › “The project appears to be damaged, it cannot be opened” Adobe Premiere Pro V. 7.2.2
  • “The project appears to be damaged, it cannot be opened” Adobe Premiere Pro V. 7.2.2
    Posted by Barry O’brien on December 12, 2014 at 5:37 pm
    I have a question. I have a Adobe Premiere Pro project that I created on a Mac Pro dual core, running OS 10.7.5. The project is on an external hard drive, and I think all the required files are inside the master project folder.
    I took the hard drive over to an associates and tried to open it on his Mac Pro, running OS 10.6.8 and his version of Premiere Pro CS6
    I got a warning: “The project appears to be damaged, it cannot be opened”
    I came back and tried to open the project on another Mac Pro 8 core also running 10.6.8 and Premiere CS6. I get the same warning.
    Is it because you can’t go backwards from CC (7.2.2) to CS6?
    Thank you in advance.
    Barry O’Brien
    I am just a few months into using Premiere Pro, so
    Barry O’brien replied 11 years, 9 months ago 2 Members · 2 Replies
  • Ann Bens
    December 12, 2014 at 6:22 pm
    [Barry O'Brien] “Is it because you can’t go backwards from CC (7.2.2) to CS6?”
    Yes!
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Barry O’brien
    December 12, 2014 at 6:46 pm
    OK, great. Thanks! Case closed.
    So if I upgrade my other computer to 7.2.2 I should be able to open the project on either machine?
    Are the newer versions, beyond Premiere Pro CC 7.2.2. stable? Are there any downsides to downloading the newest version?
    I have limited memory – 9 Gbs.
    Thank you,
    Barry
