Activity Forums Adobe After Effects The opposite of precompose?
  • The opposite of precompose?
    Posted by Lazlo Hollyfeld on August 27, 2005 at 12:49 am
    Hi There,
    Quick question. Is there a way to “un-precompose” a layer in AfterEffects. I’m not speaking of “undoing” a precompose command, but if I want to “expand” a composition that exists in my current composition, is there a way to do that?
    Arie
    Dmitry Lyapustin replied 10 years, 10 months ago 3 Members · 2 Replies
  • Mstleger
    August 27, 2005 at 3:23 am
    Usually, I would either copy the layers and paste them back in the comp you want them to be in, or I would make the needed adjustments in the precomp. Also, there is the option of collapsing transformations, which is often usefull when pre-comping 3d layers.
    This issue is the sole reason I find myself using shake a little more often, although I’m still a little faster working in AE.
  • Dmitry Lyapustin
    November 19, 2015 at 12:24 pm
    This script will help you https://aescripts.com/un-precompose/
